Build Log Shapeoko 2 #CHB01
Postby Ardrake » Tue Feb 13, 2018 2:18 pm
So after building a cheap 3D printer, I decided I needed to spends hundreds of dollars to build a desktop CNC to cut parts required to upgrade and make this cheap printer better! go figure :-) sometimes I wonder how I lived to be this old... hehehehe I admit I like building stuff and learning in the process.
So my cheap printer the ANET A8, was build from an open source kit (based on Prusa I3), So i looked at the CNC open source available and decided to go the shapeoko way and to make things more interesting and possbily cheaper, I opted not to buy a kit. I Printed out parts in ABS plastic, I localy sourced the métal plates from a laser cutting shop, purchased makerslide extrusion and wheels from Inventables, and the remainder I bought from aliexpress, Amazon, and a local hobby shop (Futur Energies, Verdun Quebec), always going for the cheapest price, and would upgrade later if required / needed.
After 6 months and a lot of wating for shipping I have 1000 X 1000 machine that is working, you can see some of the build on OpenBuilds, at this link
https://openbuilds.com/builds/cnc-greenland-paddle-carver-build.6221/
This was before I started hanging out here on the Shapeoko formus :-) On a side note, my summer hobby is Kayaking, so I figured I could also use this CNC to carve out a Greenland Paddle, thus the build name and directions noted in the openbuild listing, more to follow on this.
My Shapeoko2, runs a cloned arduino U3 and V3 Cnc Shield (also clone), GRBL 1.1, UGCS front end. I have a cheap dremel knockoff whom I had laying around as a spindle.
The spindle will be my first upgrade. Currently looking at a used Bosh Colt (70$) and / or a new Dewalt 660 clone, I must like to complicate things for myself hehehehe! More to follow on this as well.
1000 X 1000 ShapeOko2 #CHB01, 500W cheap chinese spindle, Arduino Uno/CNC-shield and GRBL 1.1
Anet A8 + Flash Forge Dreamer 3D printer
Solid Edge / Fusion360 / EasyCAM
Ardrake
Re: Build Log Shapeoko 2 #CHB01
Postby Ardrake » Tue Feb 13, 2018 3:38 pm
Random Alarms / stoppages
I've gotten random stoppage, So after reading several possible causes I did a séries of test, to try to pinpoint the source of the problem.
Set up 10min job, raised the Z - 0, 2 inches above material
test -1 - dry run, no pwer to spindle, no power tu dust collection (vacuum) - SUCCES
test - 2 - dry run spindle on, dust collector off - SUCCES
test - 3 - dry run, spindle on, dust collector on - SUCCES
so that went well, but no indication on what was causing my alarms etc.......
test - 4 - Lets cut!, spindle on, dust collector on - Random ALARMS... */"($&/($&* ....again but noticed lots of static electricity on dust collector hose, (dust particle standing straight and alligned on tips of hose) hmmm could this be it
test - 5 - more cutting - re-run last job, Spindle and dust collector on ! - after 5 minutes, touched the metal part of my dust collector hose, ZAP get a static discharge, and BAM, alarm is triggered!
So I need to ground or reduce / eliminate de static build-up caused by the dust travailling in the hose, on the dust collection system..!!
Well at least I know where to start, more to follow...
Ardrake
Re: Build Log Shapeoko 2 #7354
Postby Gadgetman! » Thu Feb 22, 2018 7:48 am
You can upload pictures of your machine here...
This is a custom machine, not from a kit?
Where does the #7354 come from?
Gadgetman!
Postby Ardrake » Thu Feb 22, 2018 6:29 pm
Yep, not a kit, home build shapeoko, pretty much same specs, for the number I improvised, searched forums and took the last number plus one, probly not an issue since I don't think they sell 2's anymore, if it is I will change it.
I will add some pictures soon, since my la last post I've added belt tensionners for the X axis. I think I had loose belt chatter / deflection on cuts caused by this, or a loose Z axis plate, I will probly re-build the Z axis, if the tighter X and Y belts don't resolve the issue.
I am currently using GT2 steel wire belts, very little flex... don't know if it's better or not yet!
Ardrake
Postby Ardrake » Thu Mar 22, 2018 12:40 pm
Installed 500w spindle, worked on noise suppression (ferrite core, twisting cables and shielding) test cut my work Logo, 25 min job, no stoppages or problems :D
Short video of spindle cutting MDF
https://youtu.be/dvoV0ANk9hE
Next on my list, clean up and finalise my control box, and work on dust collection system
Ardrake
Postby Gadgetman! » Mon Mar 26, 2018 12:16 pm
You can't just post a video of your machine cutting something.
We want feed speed, cutting depth, overlap, size and type of endmill, and how many flutes.
We want DETAILS!
Gadgetman!
Postby Ardrake » Mon Mar 26, 2018 12:36 pm
Fair enough!
Feed rate : 30 in/min
plunge rate : 9 in / min
cut per pass : 0.028 inches
step over : 40%
End mill : HQMaster 1/8" Carbide Flat Nose, Double Flute : https://amzn.to/2IRH3va
Very safe settings, slowly fine tuning and testing my machine
Ardrake
Postby Gadgetman! » Tue Mar 27, 2018 7:09 am
Safe?
That's not much faster than what I cut through Aluminium with...
You're getting pretty close to friction-burn territory with that.
Take a scrap piece of material and run some zig-zag cuts on it, and look for distortions, then back down 20 - 25% on the speed from where you notice the distortions, and you should be good to go.
https://www.youtube.com/watch?v=VEMYajG2FZI
Gadgetman!
Return to Build Logs
Who is online
Users browsing this forum: No registered users and 1 guest
