End mills (group)
End mills (group)
Postby AtomSoft » Sun Jul 08, 2012 1:48 pm
Ok im talking to the guy i order end mills from and he is willing to give a (pack) discount.
I know there is already as topic on this but it never went through. So i sent my guy this list: (just now)
2x 0.80mm (.0315"), 2 flute, 0.120" cutting depth
2x 1.50mm (.0591"), 2 flute, 0.250" cutting depth
2x 2.40mm (.0945"), 2 flute, 0.390" cutting depth
2x 3.00mm (.1181"), 2 flute, 0.500" cutting depth
The below are engraving bits
1x 30 Degree
1x 60 Degree
or
1x 82 degree, 2 flute, .012" tip engraving bit (if available)
1x 90 degree, 2 flute, .012" tip engraving bit (if available)
Which seems to be the choices from the other topic.
His first response to my request was:
Jason, yes I would like to work with you and your group. That said, I've struggled with putting kits together for other groups/folks because they've been too vague in what they need. It would be helpful if you can put together a list of what you need in the kit, quantities of each included so that I can piece it together and price it out for you.
Oliver
I just noticed. Its the same guy as the other topic but he seems to be responding to me quickly. I sent him the request for more info yesterday and got the above response the same day.
Blog / Store
Live to Love, Not to Hate.
You're not a failure because you don't make it, you're a success because you tried.
Do you like the help i give? Think i deserve a tip? DONATE
AtomSoft
Re: End mills (group)
Postby Karl » Thu Jul 12, 2012 11:54 pm
I would be interested in this. Any more news?
Karl
Postby jrsteensen » Fri Jul 13, 2012 3:02 am
I'd be interested too!
jrsteensen
Postby Micha » Fri Jul 13, 2012 4:08 pm
+1 I'm interested too
Micha
Postby AtomSoft » Fri Jul 13, 2012 4:52 pm
Im trying to contact him and indeed he is being kind of unreachable. I just found his email so i emailed him. Im not sure if its eBay not allowing messages or his box is too full or packed.
Blog / Store
AtomSoft
Postby AtomSoft » Fri Jul 13, 2012 9:50 pm
Ok he contacted me back and is going to setup something over the weekend. Ill keep you guys/gals* posted...
* = if any
Blog / Store
AtomSoft
Postby RSWeaverAz » Fri Jul 13, 2012 10:44 pm
@AtomSoft
I might be interested as well, what is the shank diameter?
Can I assume these are for milling metal rather than wood bits?
My ShapeOko is still sitting in its delivery box ... but i did pick up a Harbor Freight cutout tool this week,
on sale now for ~ $25.00 U.S Looks much like the Yellow Dewalt.
Has a 2.6 inch diameter for about 3 inches of its length and also has a mounting collar that's ~ 1-3/4 Inch Diameter.
28,000 RPM and has 1/8 and 1/4 " collets.
http://www.harborfreight.com/electric-cutout-tool-42831.html
Saw a good idea for mounting the cutout tool using 2x 2-1/2" Pipe hanger clamp's and possibly a 1-3/4 inch if available:
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100172448&R=100172448
Also picked up a inexpensive Stand for the ShapeOko and ORD Bot, also at Harbor Freight for ~ $27.00 US
http://www.harborfreight.com/adjustable-height-heavy-duty-workstation-46725.html
Edit: The harbor Freight stuff is on sale until 7/31
I Launch Rockets
, aka High Tech Welfare for Engineers
Your tax dollars have to go somewhere ... right!
ShapeOko S/N 396
RSWeaverAz
Postby AtomSoft » Fri Jul 13, 2012 10:55 pm
Cool, the bits are all 1/8" diameter. Thanks for the link(s)...
Blog / Store
AtomSoft
Postby AtomSoft » Sun Jul 15, 2012 9:10 pm
Check it out guys:
http://www.ebay.com/itm/380455286450?ru ... 26_rdc%3D1
Thats 10 bits for under $40! You cant go wrong, I use his bits right now and they are awesome!
Also just did my case for the Raspberry PI.. thought id mention it since i used his bits for this.
Blog / Store
AtomSoft
Postby RSWeaverAz » Mon Jul 16, 2012 4:59 pm
@AtomSoft
Amazing how much better the case looks in clear plastic.
I looked at the ebay posting, bits look good and my question on cutting metals was also answered, not that I like the idea of using fluids ...
These tools are built for cutting FR4 and plastics, but should be strong enough to cut aluminum, copper, and brass under fluid. The tools have a plastic ring for ease in identification and depth control.
So i guess we are waiting on his callback on such things as minimum group size, shipping and of course cost ...
Also a question on the AtomCNC board, did you consider the Atmega 644P, has 64K eprom to handle future code growth, and way more I/O pins.
possibly add a Arduino compatible shield headder array and add (future) support for LCD's or a jogger control box
http://www.ebay.com/itm/260953769194?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
Ya, I know its probably to late to mod the AtomCNC, but for Rev2
I Launch Rockets
ShapeOko S/N 396
RSWeaverAz
Next
Return to Discussion
Who is online
Users browsing this forum: No registered users and 1 guest
