by edwardrford » Wed May 23, 2012 2:27 pm
If the motors are laying on the table, shafts pointing towards the ceiling, the correct orientation should be:
Y = Counterclockwise
X = Clockwise
Z = Clockwise
If we explain it 1 axis at a time:
g0X100: Tells the X axis motor to go 100mm. 100 positive mm on the X/Y system would move the carriage to the right (if looking at the machine from the front)
g0 y100: Tell the Y axis motor to go 100mm. 100 positive mm in the X/Y system would move the gantry *away* from you (if looking at the machine from the front). This is assuming your motor is mounted on the right side of the gantry (again, if looking at the machine from the front)
g0 z100: tell the Z axis motor to go 100mm in the positive direction. This moves the Z axis up toward the ceiling (raises the z-axis away from the work surface)
