I believe that the Home feature is what is what is implemented at the start and end of a run and when the board reset button is pressed. My understanding of GRBL, and anyone feel free to correct me, is that you manually position the gantry and spindle at a start point. You then press the reset button. After that, GRBL keeps track of where it is in relation to that assigned point in space, and considers that point as "Home". If you connected limit switches to the Home button, the results would be pretty disastrous.
( Made using CamBam - http://www.cambam.co.uk )
( Untitled 2/13/2012 2:54:50 PM )
( T0 : 0.0394 )
G20 G90 G64 G40 (INCHES, ABSOLUTE DISTANCE, NA, NA)
G0 Z0.125 (MOVE TOOL FAST (NO CUT) at Z0.125 )
( T0 : 0.0394 )
T0 M6 (Tell program tool)
( Engrave1 )
G17 (SELECT XY PLANE)
M3 S1000 (SPINDLE DIRECTION and SPEED)
G0 X-3.0 Y-0.0451 (MOVE TOOL FAST (NO CUT) to XY)
(BELOW START CUTTING)
G1 F10.0 Z-0.001
G1 F60.0 X-2.8845 Y-0.035
G3 X-2.8723 Y-0.0943 I0.3244 J0.0363Absolute Mode: (0 is center)
G28
G90
G92 X-100 Y-100 Z0Incremental Mode: (0 is center)
G28
G91
G92 X-100 Y-100 Z0Users browsing this forum: No registered users and 1 guest
