Missing Part
Missing Part
Postby AtomSoft » Mon Jun 18, 2012 10:29 pm
Ok i think there is a mistake with quantity on my parts. Im missing 2 M5 screws for the belt axis... ill check on eBay :) its the M5 x 10
Blog / Store
Live to Love, Not to Hate.
AtomSoft
Re: Missing Part
Postby edwardrford » Mon Jun 18, 2012 11:23 pm
Most hardware stores have M5 x 10mm screws. Ace, True Value, Menards, Lowes, Home Depot, Wal-mart might even have them.
How many did you get in your pack?
Shapeoko #0 - a couple of upgrades.
Re: Missing Part
Postby AtomSoft » Mon Jun 18, 2012 11:26 pm
To be totally honest i did not count but i did a count on whats screwed down... about 20... maybe its just me going crazy :(
Ill try homedepot tomorrow
Blog / Store
AtomSoft
Re: Missing Part
Postby edwardrford » Mon Jun 18, 2012 11:38 pm
If I remember correctly, there should have been 20pcs included with the kit. Any chance you used 2 on the z-axis plate instead of the 16mm screws?
Re: Missing Part
Postby AtomSoft » Tue Jun 19, 2012 12:03 am
Ill check... sounds like a mistake i would make too :)
Blog / Store
AtomSoft
Re: Missing Part
Postby AtomSoft » Tue Jun 19, 2012 12:07 am
I did use 2 on that plate but it says to in the documentation:
http://www.shapeoko.com/wiki/index.php/Assembly_step_6
Blog / Store
AtomSoft
Re: Missing Part
Postby edwardrford » Tue Jun 19, 2012 1:14 am
Nope, you're correct. The two screws that hold in the delrin nut are M5 x 10mm. I was referring to the two screws that bolt the z-axis mount plate. Step 9, item #3, part SM-H13.
Re: Missing Part
Postby AtomSoft » Tue Jun 19, 2012 1:45 am
:) i checked those now... i have 16mm on them... its ok.. ill get M5 x 10mm
http://www.homedepot.com/h_d1/N-5yc1v/R ... reId=10051
Ill get a few packs ... just in case i get more maker slide in the future :D
Blog / Store
AtomSoft
Re: Missing Part
Postby jackrats » Tue Jun 19, 2012 11:30 pm
I also seem to be short 2 of these. As well as 2 x 3/4" nylon spacers.
I just counted what I used, and there are definitely 20 in use, which is what the bag says.
8 - for mounting the base plates to the lower Makerslide sections
2 - for mounting the delrin nut
4 - for mounting the rotary tool mounts to the Z axis Makerslide
4 - for mounting the x axis Makerslide to the gantry sides
2 - for the y axis belt clips
But I'm missing 2 for the x axis belt clips
I'll just grab some at Lowe's, but might need to update the BOM for the next run. The BOM seems ok for the spacers, it looks like I was just shorted 2 of them.
jackrats
Re: Missing Part
Postby zimmer62 » Fri Jun 22, 2012 4:54 pm
I was missing the two screws as well. I'm pretty sure the kid needs 22, not 20 as listed on the parts list.
The directions and pictures don't talk about the belt clips for the top, I think this is why they were left out.
zimmer62
Next
Return to Assembly
Who is online
Users browsing this forum: xtonyx and 1 guest
